Help extruding profles generated by parameters
tobias.vogel
tobias.vogel
I need to extrude profiles from a sketch according to parameter settings.
How can I acheive the extrusion of all profiles from the sketch even
after changing the number of profiles parametrically as in the screencast below?
-> Screencast <-
TrippyLighting
You'd sketch one circle and extrude-cut it. Then instead of using a sketch pattern you'd "Create->Pattern" the (timeline) feature of that extrude-cut.
