Im trying to build this LED spacer to mount a lef light at a 45 degree angle on a flat surface. I have the face neds the fit the led light but can not figure out how to extrude it stright down to the low flat plane?? i have tryied sweep it will work buts destores the object??? im lost
thanks for the help.
Many ways to do it, but using your file data, (thanks) you can
Create a Patch > Patch body from Sketch 1, that suit your purpose.
Create a Sketch on Plane 2, and Project the Patch Body to that sketch,
Hide the Patch Body.
Extrude the New Sketch to Object and Select Plane 1.
For next time:
Use the origin for symmetry,
Don't delete when Fusion warns you not to, just hide (it) with the lightbulbs, instead.
Might help....
