Help editing an imported .3DM file
Hi
I am trying to 3D print this piece downloaded from Thingiverse. ( http://www.thingiverse.com/thing:787994 )  Its the carriage to carry a camera, which runs on two guide rails, two linear bearings fit into the the two highlighted holes. The designer has kindly included the Rhino 3DM file. The problem I have is the diameter of my bearings is 1mm smaller than the printed hole and so are a very loose fit.
Is there anyway to make  the holes slightly smaller so they are a tight fit on the bearings? if so how best to do it?
thanks
cekuhnen
@Anonymous for this task if the data is good you should be able to modify the sphere / cylinder radius with the solid modeling push command.
Works wonders in Fusion 360 to be honest!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Indeed that works and so simple, thanks for helping.
cekuhnen
@Anonymous Glad it worked. Fusion is amazingly good when editing solid models.
Claas Kuhnen
