Help Editing an AutoCAD drawing in Autodesk Inventor Fusion
I need help editing a .dwg file in Inventor Fusion.  I have a 3D solid in AutoCAD that I think was created and then imported from Inventor Fusion.  When I click on the solid and hit the "Edit in Fusion" button it open up the file in Fusion, but the only item in the task bar is for a solid (Solid 1 file) instead of having the different features that I can edit (Solid 2 file).  The Solid 2 file was created in Inventor Fusion and saved as a .dwg where as the Solid 1 file was given to me as a AutoCAD file with an imported solid block that I am trying to edit.  Am I missing something or am I not able to edit the file for Solid 1?
Mark.Lancaster
@Anonymous
Are you talking about the obsoleted Inventor Fusion (2013) package or actually Fusion 360?   Inventor Fusion 2013 is a retired product and you should be using Fusion 360.
Mark Lancaster
I have Inventor Fusion 2012.  I know that it is outdated, but it is what I have to work with at the moment.
Mark.Lancaster
@Anonymous
Well its 6 yrs old and I never used it that product.  Not saying no one will come along and assist you but its an old product and I'm not sure how many here actually used it and remember how it worked.
Mark Lancaster
kelly.young
Autodesk Support
Autodesk Support
Greetings @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
You'll probably find more experienced users of the 2012 release in the Fusion Forum.
Moving your post over there for better results!
