Help editing a AutoCAD drawing in Autodesk Inventor Fusion
I need help editing a .dwg file in Inventor Fusion.  I have a 3D solid in AutoCAD that I think was created and then imported from Inventor Fusion.  When I click on the solid and hit the "Edit in Fusion" button it open up the file in Fusion, but the only item in the task bar is for a solid (Solid 1 file) instead of having the different features that I can edit (Solid 2 file).  The Solid 2 file was created in Inventor Fusion and saved as a .dwg where as the Solid 1 file was given to me as a AutoCAD file with an imported solid block that I am trying to edit.  Am I missing something or am I not able to edit the file for Solid 1?
SaeedHamza
What is Inventor Fusion?
This is an Inventor question, so I recommend you ask this in the Inventor forum : https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Regards
Saeed Hamza
