Help deleting weird geometry fragment
PetePayne
PetePayne
I am trying to delete the small pie shaped piece of geometry and can't seem to do it. Part of my goof up was the design history was turned off at the beginning. All help is appreciated,
wmhazzard
The best way to delete that face is to start over from scratch. You are making it way harder than it needs to be, two or three sketches and a few extrudes should be enough to build that.
wmhazzard
With no dimensions I made the bracket with 2 sketches, 2 extrudes and a fillet. You can look through the file for the steps involved.
PetePayne
Thank you! I am down loading it now and checking out your process. Learning every day with help from you good people on here.
wmhazzard
I hope it works out for you and if so, please mark as solved.
PetePayne
Ok, I had to update so I could open the file .
Your way loos a lot better .
Thanks for the help wmhazzard!!
