- Mute
- Permalink
- Report
Spent quite a bit of time trying to find a solution for this, however it has proven to be less straight forward than I expected. I am trying to create a dimple (to basically reduce material) set in on the blue areas of this screen-shot. Shell doesn't work due to the complex curves here, though I had expected it would. Push/Pull (Offset) doesn't either because of the curved surface – and that was the first thing I tried. I've seen some posts about possibly using loft? In this example, I'm looking to indent straight into the object a uniform distance from the outer surface, and then I'll do a 2mm filet around that edge.
Sorry for the "noob" question, appreciate the community support.
Stephen
