Help creating a simple part
m4vrick99
m4vrick99
Hi all,
My question is, I guess, really easy for you guys. But I'm new with Fusion, coming from sketchup.
I'm trying to add a reinforcement to a simple L part, but I can't figure how to do this.
Attachments show the actual part and a similar part I've made in sketchup, my question is only concerning the slope reinforcement (on the left in sketchup).
carl_bass
One simple way is to make a sketch on the edge of the L. Draw a line to complete the triangle and then extrude it
https://screencast.autodesk.com/Main/Details/23a434b0-4781-4d99-a135-9fcdb5f8876d
rhudaynath
The feature that you want to create is called as 'Rib', it will add strength to L bracket.
You can use Model -> Create -> Rib  command for this. Rib is special command for this purpose.
Rhudaynath
Software Engineer
m4vrick99
two great solutions. Thank you 😄
