Help! combining components from separate design files
I mistakingly started a new deign window when making the seperate comonents for an assembly im trying to create.  Is their a way to combine these componenets so that i can assemble them or do i need to re draw them all in the same file?  I come from solid works so i took the wrong approach unfortunatly.
TrippyLighting
Start a new design file.
Insert the components you created (in the data panel) files into that new file.
They will show up there as linked components.
Break the links before you save the new file.
Hello, I am having the same problem. How do I insert the components into the new file. I tried drag and drop but it doesn't work and I can't find an insert button. Thanks!
TrippyLighting
Right-click on an item in the data panel and select "Insert into Current design"
