Help! Can't figure out how to model a part...
Got some great help here the other day that taught me something new, now I'm hoping I can get some similar help on a new roadblock.
I'm trying to create something similar to the attached image... well, the top rounded part at least. gravity_rod_by_johnny_radar-d6x0zl5.jpg
It needs to be 2-inches in diameter at the base (ignoring the rings below) and then taper up to a rounded tip. I can't figure out how to do such a thing and all my experimenting is not getting me anywhere. I'm guessing it is probably pretty easy (like most things in Fusion are once I figure them out or am shown), but I can't seem to get it right.
jeff_strater
Loft to a point with tangency conditions.  Screencast coming soon.
Jeff Strater
Engineering Director
jeff_strater
screencast is below:
Jeff Strater
sanket223.patil
Do you have more dimension for that upper part . Well , you can also use revolve to create that part . First create a sketch and then use revolve command to create that shape .
Sanket Patil
Mechanical Engineering
Expert Elite
