Help adding Ribs
Help adding Ribs
SGoldthwaite
Help adding Ribs
SGoldthwaite
I've never used the rib feature and I'm having trouble figuring it out for my project (f3d file is attached).  I want to 3D print this hex wrench stand and I'd like to put a rib across each hex wrench hole.  Below is a screenshot looking at the underside.
wilkhui
Hey Scott,
To add a rib you need to sketch a curve. Does the below video help?
Cheers!
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
SGoldthwaite
Thanks.  That helps.  I was able to add ribs to my part:
