Having trouble with making a 3D rectangular pattern
Hi, I made a part with a bunch of features such as extrusion and revolve and I wanted to make a rectangular pattern of those features on the same object but I always failed to make what I wanted. It seems like when there are too many commands or too complicated design, Fusion 360 has troubles with proceeding it, is that true? Thanks.
tallisb
Hello-
Would it be possible for you to share a picture of what you are trying to accomplish?  Or, better yet, can you share your model so we can try and recreate what you are trying to do?
Thank you.
Brad
Brad Tallis
Fusion 360 Technical Specialist
jhackney1972
Could you please attach a model that contains the desired array?  Also describe the exact array you are attempting.  Here is a 3D array of a 1 inch cube.  Normally, with good modeling practices, I have not observed any issues creatng this type of array in Fusion 360.
John Hackney, Retired
laughingcreek
@Anonymous wrote:
...It seems like when there are too many commands or too complicated design, Fusion 360 has troubles with proceeding it, is that true? ...
No, I have not found that to be the case.  I have found that more steps = more opportunities for user error, and more chances of those errors snow balling into a mess.
