Having trouble splitting a body
Lehrer_Account
Lehrer_Account
Hey guys. I'm pretty new to all this and I'm trying to get some practice in. After creating a few small things I was trying to trisect a cube. It turned out to be a pretty good exercise but now I'm stuck at seemingly the last step. I created spirals to cut into the cube but I get an error: "coincident tools would create illegal or non-manufacturable bodies".
Where did I go wrong and how can I fix this?
sutherland-
Hi @Lehrer_Account
Please try using "Combine" feature. It sounds crazy, but the this feature also has cutting.
Refer to image below:
P.S. Really nice outcome you have there! Good job!
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
TrippyLighting
Another tip here to make creating the helix easier.
Use a surface sweep with twist and then thicken the helical surface. Often much easier to control than the dreaded coil feature and it creates cleaner geometry as well.
Lehrer_Account
Thank you both for helping out and thanks for the compliment. I ended up having to go with the second solution and the sweep tool. Because with the first option I was unable to move the sections it created around. It stayed as one object with a piece cut out. So in this case the other option was better.
