Having trouble rebuilding parametrically using projected points
- Mute
- Permalink
- Report
Hi Folks,
I'm trying to create a boat hull. I would like the hull to be parametric such that it updates when I make changes to the foundational sketches that drive the hull's design (e.g. side view, top view, sheer, and sections). I'm using the PROJECT function to snap the splines of the section drawings to the aforementioned driving sketches. When I go back to change one of these driving sketches, however, the sections don't seem to update. Rather, they remain in their original spots. (Even sketch elements within the original sketch that are coincident-constrained don't seem to update.)
To update the offending elements, I've been deleting the projected geometry (and/or a number of constraints) to release the splines, re-project the points I snapped them to and then re-constrain the splines. It seems like these should just stay locked to the projected geometry (like a PIERCE constraint in other software) and update parametrically. Can you tell me what I'm doing wrong?
Further, I'm having some trouble with basic spline and constraint control. Sometimes I can't get the spline handles to appear. For example, If I have a point and horizontally-constrained line attached to the spline, I can't access the spline handles. (These elements are to be driven by the spline, as their only purpose is to give me a point for a future projections — again, in lieu of a pierce constraint.) It seems like I can only control the spline handles once I've deleted other elements that should be driven by it.
D.
