Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I am currently learning how to work with the imported DWG file in Fusion 360.
I can import the file and I want to convert it to sketch so that I can setup the dimension and constraint.
I used the sketch project command to get the sketch, which can be edit now. But it shows so many points on lines. I can manually connect lines to remove the point, but I wanna know if there is a better and faster way to remove those points. Thanks so much!
