Having problem with reference image tilt issue
Hello everyone I'm a new fusion 360 user. while using fusion 360, I have come a cross a issue. Every time when I paste the reference image to draw a model, doesn't matter which plane I'm using. weather it is in the front plane, or back plane. After I have pasted the reference image it's always tilt. In this particular situation, when I'm in the Left side plane, the top plane reference also visible. for all of your assistance I have  also attach the issue below. Thanks for your time.
Accepted solutions (3)
Prashant_Jha
Just check your view orthographic or perspective at the arrow below the view cube
Man I just don't know how to say Thank you. Man I'm deeply appreciate your help. & the time you took out to read & reply.
Have a great day mate.
ritste20
I know where that reference drawing came from and I will tell you upfront, I spent 2 weeks deciphering it. I would keep it as a reference but just know that the dimensioning scheme is not intuitive.
If you are brand new to fusion, that is not an easy project to take on. If you are determined, I wish you the best of luck.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Thanks for the heads-up. I'll keep in mind.
