Having issues with tracing to create pocket cutouts
fritter63
fritter63
Ok, having a heckuva time getting this to work. I'm trying to create a "cutout" in a box bottom to precisely match a pair
of wine bottle openers. My POC is not doing so well. See attached pictures. I've taken a picture of the openers and loaded them into F360, then scaled them along a known dimension.
Then I used splines to create a tight outline of the shapes, and then offset the shape by .5 mm to give me some play in the cutout.
When I cut it on the CNC machine though, the cutouts aren't very accurate. Actually, ONE of them is, but the other isn't. There seems to be discrepency in the 3D recess after I have push pulled the sketch outline into the surface!
Picture 1: Canvas with trace outlines. YOu can see that the offset outline leave plenty of space around the opener
Picture 2: 3D model showing that I have correctly selected the outer outline to extrude into the solid
Picture 3: A "bleed through" of the 3D shape, with the canvas visible. Note that the top of the outline does not appear to be the right offset curve, it is the tighter of the two, even the bottom seems to be fine. NOTE that the end of the corkscrew has plenty of room.
Picture 4: Picture of hte actual part after machining. Note that that tool barely fits, and that the end of the corkscrew is off by a good 4 mm. It is just to long for the cutout.
What is going on here? The differences are inconsisent and couldn't be chalked up to innacurracies in my machine (which I doin't believe there are).
fritter63
Here is the fourth picture since it wouldn't let attache more than 3 images....
HughesTooling
Can you export the f3d file and upload, can't help much without the file.
Mark
Mark Hughes
Owner, Hughes Tooling
michallach81
I suspect that it's caused by lens distortion. To see difference try scan your corkscrew, and I do mean to make a scan in your printer/scanner device. There will be some distortion, but at least main body outline will fit.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
fritter63
@michallach81
I considered that, but wouldn't lens distortion have made the outline larger not smaller?
michallach81
Not quite, it will distort image. Mainly, whatever is in focus will appear bigger, and what's no edges will be smaller. So, depend on how you've scale it it will be to thick in middle or too short on the ends.
Michał Lach
Designer
co-author
fritter63
@michallach81
That was exactly it. I re-scanned and re-did the tracings and they came out perfect.
