Hatch issues in Drawings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
The section hatches in the drawing workspace are currently my biggest pain point in Fusion, I'm hoping someone has a workaround. If I have a complex model that needs section views (which all my drawings do), I have to manually edit every single hatch (pattern, scale, and angle) in order for it to be readable. This can take me 15 minutes per section, or hours per drawing set.
Finally, I thought that I'll just remove the hatches from the drawings and do it manually in Morpholio for iPad or even Illustrator...but I can't even create sections without hatches. If I set the default color to white, it still shows up, intersecting the outer lines.
How does anybody else do this? Surely I'm not the only one. Do you create your drawings in another program? Is it possible to create a script or add-in to change multiple hatches at once?
Please help.
