Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Hard challenge - Rice paper lamp
6 REPLIES 6
hpekristiansen
673 Views, 6 Replies
This is just a challenge for those who find it fun. I do not need help with or the result of anything - though I am interested in how people solve the problem. -I was not able to do it perfectly myself.
My rice paper lamp has a bamboo stick in a spiral!
How can one make a spiral going down and back up on a sphere, where the down and up parts are perfectly joined without kinks?
My own attempts:
My lamp with just a spiral down:ScreenShot2019-10-01T220409@1X.png
A better spiral (not perfect, because of an estimated angle - notice the kink at the bottom):
Tags (2)
6 REPLIES 6
etfrench
in reply to: hpekristiansen
The helix can't have a constant pitch for this.  One way to change the helix at the top and bottom is to fillet the joints.
ETFrench
janie.ypan
Could you possibly post a download file for this? Thanks
You'd probably need to create a series of points in another program and import them to get a mathematically correct spherical helix.
https://mathworld.wolfram.com/SphericalHelix.html
https://www.mathcurve.com/courbes3d.gb/helicespheric/helicespheric.shtml
If you just want to get close you could do something like this:
https://www.youtube.com/watch?v=RoRPrilJ388
Julian Groeli
Owner
2020 Design
It is no problem to create a spherical helix in Fusion - no need for the API or any external program. The challenge is about connecting the helix that goes down, and the one that goes up. That is why I consider this a hard challenge.
hpekristiansen
in reply to: janie.ypan
This is a challenge - I am interested in seeing how you will solve it.
Anyway, I have attached the files, if you need inspiration or a starting point. (Note that I was not able to solve the problem myself)
@hpekristiansen OK, thanks for the clarification.
See attached model for a reasonably close approximation given the tools available in Fusion. We could get closer to perfect with a "3D spline on surface" tool, or an adjustable pitch option in the helix tool (as @etfrench suggested), as some higher end CAD tools have.ricepaperlamp-jgroeli.png
Julian Groeli
Owner
2020 Design
