Guidance with quantities in the drawings
Hi, I've posted about similar issues in the past and thought that I had more or less figured it out. But while creating the drawings for my latest project today I found myself getting really annoyed with myself and the software. I'm not sure if it's mostly my fault or if it's a mix of software too. Please advise.
To explain the issue I had, I've designed a security cabinet that is a metal frame with 12mm round bar as the walls, basically like railings. I created one bar as a component, then copy pasted it and then used the joint command to create the rest, 40 to be exact, and used the same method for each of the other bars that needed to be different lengths. So in total over 100 bars of differing lengths. Well here's the problem I had with the drawing space. I usually create the drawing just of one of the components and use the table to give the quantity of all of the matching components. Only I had to go into the list on the left, tick ALL of the other components that where duplicates, then open each component so that I could turn off the bodies, so that they didn't show in the drawing. That took forever and I almost gave up. Is there a better way to do that? And why not give us the ability to edit the quantity in the table? I came here because I just can't see another way to do this myself. I also have a question about patterning but I'll start a new post for that if needed. Thanks for any help and sorry to make such a long winded post.
