Groups of bodies from imported DWG file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a recurring workflow where I am given a DWG file to be turned into a 3D stamp. I import the DWG and basically treat it as a sketch, selecting all of the lines/curves, then extruding them into surface bodies. I then select these bodies and thicken them to create the stamp surface lines.
The problem comes in when I initially extrude the lines - some of them create single bodies, others create multi-surface bodies. If I try to thicken once of the multi-surface bodies (e.g., like 104-106 in the attached picture), it often blows up with one of about 3 geometry errors. As a work around, I can select each surface separately and thicken it instead of selecting the entire mult-body. It would be a lot easier if all of the bodies were separate to begin with - I could select them all from the browser and thicken them together. Is there a way to break up these groups, or stop them from being created in the extrusion step to begin with? At first, I thought this was something peculiar to the DWG file, but none of the files I use have polylines, groups, blocks or any other type of multi-elements - it is all simple geometry. Thanks in advance for any insight.
