Grouping componenets.
107merc
Message 1 of 12
107merc
I grouped Rigid Group 9 & 10, saved the file then closed it. Opened the file the next day
and the components were no longer grouped. They act individually. How do I get a group
to remain together??
Replies (11)
Message 2 of 12
jeff_strater
seems to work OK for me:
Jeff Strater
Engineering Director
Message 3 of 12
107merc
Sorry if I wasn't clear enough. I can assemble the drawer as one unit and the box
 as one unit then move the drawer in and out of the box to show the relationship.
If I close the file and reopen it later all the components are separated.
Have posted the altered file with the components reassembled.
Message 4 of 12
jhackney1972
I do not think you set up your assembly correctly.  I have created your two Rigid Groups and Ground to Parent the housing group.  I then added a Slider Joint to the drawer and added Joint Limits.  Try out the model now, it is attached.
If this answers your question, please select "Accept Solution" on my post, if not, please ask further questions,
John Hackney, Retired
Message 5 of 12
107merc
Thanks for your assistance. Where is the "slider" function in Fusion??
Message 6 of 12
jhackney1972
It is a type of Assembly Joint.  The Animated GIF will show it's location.
Message 7 of 12
107merc
Thanks again.
Message 8 of 12
107merc
I can get components to slide but how did you get the two groups to work together??
And could you make the movements between selection a little slower. I have trouble
seeing what menu selection is being chosen. Or just a step by step, ASSEMBLE/JOINT/MOTION/SLIDER etc
would be helpful.
Thanks again
Message 9 of 12
jhackney1972
I started the video with your original model. I attached the model I used in the video so you could follow along.
I have attached the model I used in the video so you can have it to follow.
Message 10 of 12
107merc
Many thanks. I was not zooming in tight enough to set the 2nd step in joint and it was doing all
sorts of weird things. All is well, thanks again.
Message 11 of 12
107merc
You really should post your explanation to YouTube. Everything involving sliders is for components
not groups and 4-5 years old. Fusions layout has changed a lot so they are hard to follow.
Thanks again.
Message 12 of 12
jhackney1972
Are you address me?  If so, you should address your Forum post to my User Name and not yourself.  As for YouTube, I do have a YouTube channel but it is geared to more advanced topics in the use of Fusion.
To use any Fusion Assembly Joint, you must have components, or at least for one side of the joint, you are placing.  Rigid Groups can be used for Joints as long as they are composed of Components.
