Group, copy/paste jointed components?
Dc555
Dc555
So I did all this work jointing these components together for this drive wheel. But I need 2 of these.. Is there a way I can copy and paste  these components and all of their joints that go with them? Basically make this into one importable assembly.
I made this by inserting these components into my main file... Which does contain other components not shown in this screenshot
jeff_strater
There is no great way to do this today, if the components are all siblings in the component hierarchy.  If they are a subassembly, you can use either Derive or Save Copy As to create an independent design containing only those components, which can then be inserted into other designs.  Sometimes, if your design is pretty simple, you can create that sub-assembly after the fact, but that is not always the case....
Jeff Strater
Engineering Director
