I am trying to design a PC case and among its features is a hexagonal pattern for all the air intakes and exhausts. I used Rectangular pattern to produce all of my hex shapes after sketching and used Extrude to make the cuts into the case to make the vents. I immediately noticed significant processing time and even hangs when producing and selecting these patterns but managed to pull through. I have switched to low graphics mode. I have done much of my work on a more powerful desktop with a R7 5800x and 128 gb of ram. I also noticed that suppressing features and sketches that were not important at the moment made computes much faster. However, I'm stuck at the last, biggest and most complex pattern, the main air intake. I have only been able to do half of the pattern; I want to make an identical pattern set below it with a Mirror or Copy, but I am now stuck waiting and unable to even place the feature let alone the last extrude cut. The first set of intake holes creates over 25,000 selections when I pick them all. Am I doing something wrong with the pattern that I am using that is making it too big and complex? Is there a way to make this simpler so that Fusion can render these fan holes and post process them correctly?
