Grip Effect
Grip Effect
Grip Effect
How can we create this effect of grip under fusion 360?
thank you in advance for your help
TheCADWhisperer
The feature is called a "knurl".
Usual practice would be to use a cosmetic texture to represent the physical feature.
If you need a physical cut (say for 3D printing) the process is a bit more work involving Coil feature and Circular Pattern.
michallach81
If you need to model it that follow:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
thank you very much 🙂
