EASM File
EASM File
EASM File
I am trying to upload an EASM file in Fusion. This opens my web browser and a "conversion page" comes up. There is an icon on the left that indicates that something is happening (spinning circle thingy). But after many hours nothing happens. Tried it a few times and never works. The actual object is not complex.
josef.kucera
Hi @Anonymous
Unfortunately Fusion doesn't support that file format.
The following file types can be imported into Fusion 360:
  • Autodesk Alias (*.wire)
  • AutoCAD DWG Files (*.dwg)
  • Autodesk Fusion 360 Archive Files (*.f3d)
  • Autodesk Fusion 360 Toolpath Archive Files (*.cam360)
  • Autodesk Inventor Files (*.ipt, *.iam)
  • CATIA V5 Files (*.CATProduct, *.CATPart)
  • DXF Files (*.dxf)
  • FBX (*.fbx)
  • IGES (*ige, *iges, *igs)
  • NX (*prt)
  • OBJ (*.obj)
  • Parasolid Binary Files (*.x_b)
  • Parasolid Text Files (*.x_t)
  • Pro/ENGINEER and Creo Parametric Files (*.asm, *.prt)
  • Pro/ENGINEER Granite Files (*.g)
  • Pro/ENGINEER Neutral Files(*.neu)
  • Rhino Files (*.3dm)
  • SAT/SMT Files (*.sab, *.sat, *.smb, *.smt)
  • SolidWorks Files (*.prt, *.asm, *.sldprt, *.sldasm)
  • STEP Files (*.ste, *.step, *.stp)
  • STL Files (*.stl)​
  • SketchUp Files (*.skp)
Josef
Josef Kucera
Fusion QA
TheCADWhisperer
@Anonymous wrote:
...The actual object is not complex.
Can you request *.sldasm and *.sldprt files from the source, or *.STEP file?
Yes - but just wanted to know why Fusion tries to open the file and gets stuck
TheCADWhisperer
Can you open the file in SolidWorks?  (Hint:  The correct answer is - no.  The file is created as a viewer file, not a geometry file.)
Do you have prior experience with *.easm files?
Ok Thanks - no i do not use solidworks. I just received the file which I could effectively see with the viewer but not open in Fusion.
