Grid snap only working on one axis
android111
android111
I'm trying to sketch a circle... snap is only working on the Y axis. No clue what to do here.
Also, I can't figure out how to get the drawing tools to honor grid snapping along object edges or reference lines...
Any suggestions appreciated.
thanks!
g-andresen
please show that behaviour in screencast
günther
android111
 Thanks - Ok - here you go. As you can see, grid snapping is only working in some cases. In cases where I'm aligned to a vertical edge or centerpoint, it simply "slides".
Another one shows that when trying to create a circle sketch on top of another circle, vertical and horizontal snaps along the axis don't work.
g-andresen
Activate Snap to grid
I recommend that you switch off the grid and use existing sketch elements as a reference and use the dimensioning tool.
günther
android111
Snap to grid is on.
Sorry, creating extra geometry isn't really going to work... I use grids a lot.
I'll assume this is a bug.
jhackney1972
I have checked the grid function on my system and I do not see an anomaly.  I think it is time you used the Fusion 360 Service Utility to Repair your installation.  Here is the link to the web page explaining the process.
John Hackney, Retired
android111
Holy cow, that worked.
I didn't expect it to, but it did.
