Grid Snap.... How do I disable it?
steveripplingerjr
Message 1 of 8
steveripplingerjr
How do I disable grid snapping in sketch mode?
I am sick of having to zoom in out all the time to place my sketch point where I want it.
Replies (7)
Message 2 of 8
herzinj
Hi Steve,
You should be able to turn this off by clicking the icon shown below at the bottom of the page (with the arrow pointing to it) and then unchecking snap to grid.  Let me know if this doesn't do the trick for you.
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
Message 3 of 8
steveripplingerjr
Oh thank you so much santa! You just made my day!
Wow how did i miss that.
Message 4 of 8
snap-to-grid turned off, but still snaps.
Message 5 of 8
laughingcreek
is it snapping to the grid, or constraining to other sketch elements? maybe a screen cast of what you see happening.
Message 6 of 8
I imported a png image (a little fuzzy), and started a sketch to trace it. By zooming, I can tell it snaps to grid.
Message 7 of 8
laughingcreek
How far are you zooming in?  you can't tell much of anything if your zoomed too far in, the lines will jump around and lines that are coincident won't necessarily be touching visually.  this is limitation of graphics cards.
lines are placed accurately with constraints and dimensions, no other way.
Message 8 of 8
anthonyserridge
Community Visitor
Community Visitor
I have the same issue, I have to zoom until I can easily get between 2 snaps so it doesn't cause an issue. I hate this about fusion, long live inventor.
