Green dimension lines
William_Dec_45
William_Dec_45
I tried to be specific about where to post this but couldn't really decide which forum would be correct. Pardon me if this should be posted somewhere else.
Does Fusion have any plans for changing the color for dimension lines. It's complicated enough without the the object lines and the dim lines being the same color. Just food for thought.
jhackney1972
I assume you are talking about the color of Model Sketch dimension lines, if so, then yes.  You will have to modify one of the Fusion XML files which can be a challenge.  Below is an example of my sketch dimension lines both regular (white) and over-constrained dimensions (yellow).  The choice of colors is up to you, within reason.  Let me know if you really want to dig this deep into Fusion XML files and do this modification.
John Hackney, Retired
William_Dec_45
Yes, John, that's what I was talking about. But, I have since discovered that the "everything white" can be avoided by choosing one of the two environments that have contrasting colors (green and white). Only the Gray Room and River Rubicon environments provide this luxury. All of the other environments use white on white. I should have checked before posting this.
