Graphics Issue w/ Cuts
Has anyone seen anything like the attached screenshots?
I have not had this happen before yesterday's update, really hoping its not related to that and is a problem with the file itself but between this bug and the latest CAM bugs I am loosing patience with the software. Work needs to get done and these issues are preventing it. And with that said, the downloaded file works fine in Solidworks.
The model started as an imported STEP file from Mitee Bite, made some modifications and here we are.
Any help / a solution would be great or I guess its back to Solidworks. By the way, this happens on both my desktop and my laptop so I don't believe it to be computer driven.
TMC.Engineering
Can you attach the stp file or a link to it on the mitee bite webpage?
looks more like a model issue then a graphics issue to me.  maybe cutting to the surface instead of all the way through.
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Quick update, recreated the model from scratch and the problem does not seem to exist. If it pops up again as I progress through the model I will post but so far so good.
Fine for this instance but what is it about the imported STEP file that creates the issue in the OP? I use a lot of imported models both for fixturing and parts.
Thinking you are correct, hopefully just that model and not an issue with imported STEP files in general
P/N 46500
https://www.miteebite.com/products/quick-change-mechanical-receiver-and-blank-pallet/
