Graphics error when extruding feature from sketch
zaprodk
zaprodk
Hi.
Working on a quite simple sketch, extruding the surface and excluding a new feature i found a nasty drawing error in the program, preventing me from extruding the rightmost hole in a row of three along the bottom of the sketch.
Have anyone else seen this? Is there a fix for this?
Thank you.
It definitely looks as glitch. Because from time to time just "Edit - Ok" sequence can drill that correctly.
chengyun.yang
This should be a known issue for us(see the post https://forums.autodesk.com/t5/design-validate-document/extrude-cut-pattern-generate-a-crossing-prob...). It is a tessellation engine problem which leads to this graphics display glitch. The tessellation engine team has just fixed it but we need some time to integrate it into Fusion.
Note: it is just a cosmetic issue and the model itself is still fine.
Chengyun
zaprodk
Thanks for taking the time to look at the problem and replicating it.
I will look forward to a fix - i'm happy to hear that it's only cosmetic.
// Per.
