Global variables, equations and dimensions
Message 1 of 21
I would like to see a feature where you can add global dimensions, equations and variables for your model so that you for example can assign them to your sketch dimensions. When you change the global dimensions, equations or variables it wil be updated througout the model etc. to make easier and faster changes to your model.
Replies (20)
Message 2 of 21
I think I allready found it.
Message 3 of 21
schneik-adsk
GREAT!
Kevin Schneider
Message 4 of 21
schneik-adsk
Changing to solution provided, don't want to misrepresent this as implemented based on idea station submission.
Kevin Schneider
Message 5 of 21
basm_abdrabbo
Community Visitor
Community Visitor
Driven Dimensions are not captured in the Parameters window.
Message 6 of 21
changedsoul
Is there a work around for Driven Dimentions getting captured?
Message 7 of 21
I don't think this is a solved issue. One of the problems with parameters is that they exist in the same history / undo timeline as all of the other operations. So if you go back in the timeline to a point before the parameter was added, it won't be there to use. If there is a reason that it must be this way (and I can conjecture a few) then perhaps you could simply add a flag in the parameter modify window to indicate whether you're adding "Global" parameters which exist outside of the timeline, versus parameters which are bounded by the timeline.
I have had this particular problem on a number of projects where the idea of various parameters tend to emerge organically from the project being designed.
Message 8 of 21
HughesTooling
If you roll the timeline back all parameter created are available but if you click undo after creating a parameter it is removed. Don't see the undo behaviour as wrong though as you might change a parameter and want it changed back.
Here you can see parameters created after where the timeline pointer is positioned.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 9 of 21
Sure, and I thought about that too. The solution for that is easy enough. Let the editor have its own undo/redo stack like any other type of editor would.
Here's another perspective-- if you went to add/edit items in your tools library, you'd expect them to be there and available at any position in your timeline, wouldn't you?
Message 10 of 21
I very limited work around is provided by an free add-on "Parameter I/O" that allows parameters to be read and written from/to file.
It will only help with undo, and planning. Write the parameter file, undo, read the parameter file. That way you will still have the
parameters you "undid".
It won't work with the timeline; its a horrid kludge; and Parameter IO is a quick and dirty piece of software with no error handling
that was written to demonstrate the API, and has hung around because its useful.
Message 11 of 21
Thanks, I'll check it out.
Message 12 of 21
jared2HLDX
Observer
Observer
Hello moderators, is this still not an option? It's pretty essential to have global variables across an entire project. Any idea when this will be available?
Message 13 of 21
Phil.E
Global parameters are available via Derive.
Workflow
  1. Create an empty design
  2. Add global parameters to the parameters table
  3. Make them all Favorites
  4. Save it as Global Parameters
Start a new design
  • Use Insert > Derive
  • Pick "parameters" option
  • Select the Global Parameters design
The global parameters will appear in your design.
Derive Help article
Does this help?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Message 14 of 21
martin.kudlacek
Phil, you just saved me from insanity. I was looking for this for some time now.
Just a tiny little improvement to get this right - when I am typing down the parameter name to some field, it doesn't "autosuggest" it, as with the locally created parameters. I need to know the full name. If that could be fixed, it would make it lot more easy to use.
Martin
Message 15 of 21
Phil.E
If named parameters are favorites ⭐ the search function brings them up without the full name.
In a design with derived parameters, they appear in the model parameters area and are not by default favorites.
What is your expectation? That a favorite parameter would also be favorite when it is put into another design using Derive? Glad to hear your thoughts on this.
In the meantime, find the global parameter and make it favorite after inserting it, you should have a better time with it.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 16 of 21
ritste20
+1 from me on automagically favoriting derived parameters if they are favorited in the source.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
Message 17 of 21
Phil.E
Thanks. I logged an improvement ticket for this inconsistency.
FUS-84454FUS-84454
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 18 of 21
TrippyLighting
+1 from me as well.
Message 19 of 21
volkerEF9NS
Observer
Observer
Good morning from Germany …
I have tried this solution, and it works - sort of 🙂
Maybe a misunderstanding on my part, therefor two questions:
  1. The variables in the second design, that where I did a “insert derive”, have been renamed and are suffixed with “_Ref”.  Can this suffix be altered or, better yet, suppressed altogether?
  2. when the Parameters in the first design are modified and the design is saved, they are not automagically altered in the second design, instead I need to push a button the initiate a refresh.  Is this how it is supposed to be?
with best regards
Volker Bandke
Message 20 of 21
TrippyLighting
No.
Yes.
