Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Community,
I'm a hobbyist using (free) Fusion for 3D printing and run into a problem - or out of ideas, whatever you prefer.
I have to design a 3mm circular groove in a cylindrical object . This groove will later accept a cicular sealing ring (15mm with a 2mm string), when the object to be designed will be screwed to the cylinder.
Is somebody aware of a tutorial to show this? Or can somebody explain the workflow or tools/commands to use, push me into the right direction please?
Thank you very much!
