Gimbal Joint aka. Fusion's Ball Joint
Hi TF360,
The topic of the Ball Joint and its implementation in Fusion has been a frequent source of frustration, as evidenced on The Forum, and I suspect it is even more so, although it has not been directly pronounced here.
Without draining my liver bile further, and reiterating the issue, please refer to the following posts.
https://forums.autodesk.com/t5/fusion-design-validate-document/scratching-the-ball/td-p/7567779
I am sure that the search on The Forum will supply ample thoughts to digest.
I am bringing the issue once again ... because I stumbled upon it once again ... where the Gimbal (Ball) Joint causes significant implementation obstacles, while the Spherical Joint (XYZ rotation) would offer a TRIVIAL solution.
So, here is the question for TF360...
Are there any plans to bring the Fusion kinematics toolset to the modern CAD standards?
Regards
MichaelT
