Extending a simple triangle into a triangle with different corner lengths
DragoBruder
New Member New Member
DragoBruder
New Member
New Member
I hope this is definitely the right place to ask because I got... quite overwhelmed with the options of the topic selection. Yes, I'm new here.
I Really have no idea how to go further from now on and I need to ask.
Is there any way on how I can extrude/loft a solid triangular shape into something that is still triangular but with different corner lengths? I tried lofting but its not quite working how it should.
Trying to connect A and B (and the general shape) to the already solid triangle with the corner C.
johnsonshiue
Hi! This should be doable using Surface Modeling workflow or Sheet Metal workflow. However, the image can be deceiving. Please share the f3d file here. The forum experts can help take a look.
Many thanks!
Software Test Engineer
jeff_strater
I'm not 100% sure what the goal is, but is this something close?
Jeff Strater
Engineering Director
TheCADWhisperer
@DragoBruder
This will be super simple to demonstrate with your actual file.
Attached is another option other than Loft (Replace Face).
Drewpan
Hi @DragoBruder
Have a look at Fusion RULE #0 that is pinned to the top of the forum. This will
help you get on your way to learning fusion. The Documentation has some
excellent embedded tutorials and the Self Paced Learning will give you some
good practical training about how it all works.
Cheers
Andrew
DragoBruder
New Member
New Member
I sadly was too motivated and tried to make it work. I made a 3 point offset plane and extruded that, cut the extend of it and that was it. When I firstly tried to loft it, it was making one edge angled and I couldn't make it work and got an error otherwise. Though, thanks for all the help!
