Getting this error when I try to insert a design from another document to a working document
purchase3YFLN
purchase3YFLN
Error: The path C:/Users/indra/AppData/Local/Autodesk/Autodesk Fusion 360/2MX2VFVHLHQJ6GRB/W.login/F/_XRef_/_Untitled.f8bc7ee1-8d92-41a9-841b-9683322bb95f_LV3.f3d is not a valid zip package.
Warning: Insertion of components from outside of the current project will not be associative. The component will be embedded into your document
what to do? I need this compenent in my design
johnsonshiue
Hi! Could it be related to this article?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Designs-inserted-f...
Many thanks!
Software Test Engineer
