Getting DXF sketches to scale proportionally to a parametric frame
TL;DR: I’ve got a parametric ring template working, but I can’t get imported DXF signet shapes to scale with parameters. The frame updates, the DXF art doesn’t. Looking for a clean workflow so symbols scale proportionally and stay aligned without having to change the ratio/proportions every time.
I’m building a parametric signet ring template in Fusion. The band part is working fine — it updates cleanly when I change parameters for size or proportions.
The part I can’t figure out is the signet shapes. Each ring needs a different symbol (circle, triangle, star, etc.), and with my background, it's easiest to draw them in Illustrator and bring them into Fusion as DXF sketches either inserted directly or copy/pasted.
What I’m trying to do is:
Drop a DXF symbol (in a 1x2 artboard) into a sketch.
Line it up with a 1×2 rectangle “frame” that scales with parameters.
Have the symbol scale proportionally from the center whenever the parameters change.
Here’s what I’ve tried so far:
Sketch Scale works once, but doesn’t stay linked to parameters.
Adding dimensions either over-constrains or distorts things.
Dummy construction lines give me edges to snap to, but the interior art doesn’t actually follow the frame when it scales.
I even tried a two-file Derive workflow, but the scaling wouldn't carry through.
So right now the frame updates, but the DXF symbol just sits there unchanged or the width will scale because the sides touch the side of the frame, but the height won't.
Has anyone found a clean way to make imported DXF sketches scale with a parametric frame? Ideally I’d like to be able to swap in a new symbol each time, align it once, and have it follow the parameters like the rest of the ring since I'll need multiple sizes and proportions per design.
