Geodesic Dome 2V/3V
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi All,
attention: long post! ๐
First of all I want to take the opportunity to reach out to @lars_christensen . I want to thank you for all the good resources you put out there, they're a great help!
To me: I am an electrical engineer from Germany with multiple interests and I always wanted to make things. Now my mind is not made to just make things, I need a tool that allows me to make what I want virtually and spit out plans with which I can make the actual thing. That's where Fusion comes in handy.
I spent the last couple of weeks in hospital and I took the chance to watch tons of videos, primarily of Lars, and started to get little things to work. I already made my own box with hinges and o-ring and stuff.
Now I have found something inspiring in the web and I want to put this into a param
Now if I am not too wrong this should be a Geodesic Dome 2V. The best resource for those I could find is this one: https://www.ziptiedomes.com/geodesic-dome-calculators/2v-geodesic-dome-calculator.htm . What this gives me is the dimensions of the triangles I need.
Here's what I would do:
1. Create a polygon with 12 corners on level 0 with the wanted diameter. Place it so that two corners are horizontal.
2. Create an offset plane at the height of the triangles 'A' and place another polygon on it with 12 corners.
3. Create an third offset plane above the second by the height of triangle 'B' and place a hexagon on it.
Questions:
1. Is the distance between ground level and level 1 correct?
2. Is the diameter of the second polygon correct?
3. What diameter and distance does the hexagon have?
4. How do I sketch the triangles? I have to connect the corners of the two polygons I made. Do I have to create another sketch in the origin XY plane and project the two polygons?
5. I don't want to use connectors, I want to screw each triangle to its neighbor. This will create several angles on the ends of each strut. I want to let Fusion create those angles while placing the struts. But how do I create the struts on the triangle sketches (do another sketch and project?) and how do I take care that the angles are cut?
I know I know. A long post from a newbie with a lot of questions ... I get to the point where I have placed the two polygons but because of my questions not farther. I will place screenshots as I try to follow along your answers (hopefully ๐ ).
Thanks from Germany!
