Generative Previewer
admaiora
Mentor Mentor
admaiora
is there any reason or cause for a "Previewer failed" message, causing a no previewed generative model.
But after with "Generate" I can obtain with no problem the generative model?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
scott.kohls
In general, the previewer shouldn't fail if the Generate successfully produces results for the same setup.  If you could provide sample data that exhibits this issue we could investigate it.
In the mean time, one action you might try is to see if you can reproduce the issue with the same model but on a different computer.  The preview is generated locally on the computer rather than on the cloud where the full processing is done so it's theoretically possible that there could be some issue related to the computer that you were using.
