Generative design is not generating solutions
letterle
letterle
Hello everyone,
I'm experimenting with the generative design feature. I've ran and stopped quite few simulations also I've removed a few files while the simulation was running.
Unfortunately now the explore window does not show any results. I've waited a few hours but noting seems to happen. Could it be some sim is stuck in a  queue?
https://a360.co/2Ih84c4
Your help is much appreciated
Roy
I'm having the exact same problem given the same circumstances. Did you find a solution? Could Autodesk chime in on this issue?
letterle
Patience!!!
On occasion I have had simulations (or high part count renders) that take overnight to start.
Sorry this is probably not an answer to your issue.
I wish it was my patience that was in question!
I'm doing generative design as part of an exam that is due on Monday - hopefully this counts as force majeure and my deadline is extended.
So your issue resolved itself after a while?
letterle
I'm sorry to hear that! I hope someone at Fusion can address the issue for you. In general they are quick to respond.
