Change ouncemass to gram
ElTejano
ElTejano
This may sound silly but I have been trying to get rid of this weird "ouncemass" and change it to gram since I mainly deal with smaller parts and ouncemass is not helpful. Having to do the math is a real pain, it would really be a big help if someone could show me how to change my units to grams.
I used have used several CAD packages throughout the years and this is the only one I cannot figure out or find how to do this.
Thank you.
jhackney1972
Before you start your component or body, set you units to metric and then after assigning the material, the properties will show the mass in grams.  If you do not care to use millimeters in your model, you can type "in" after the entered value.
John Hackney, Retired
ElTejano
Thank you for the reply. I was hoping I could set weight to gram only.
