Gear Animation
Gear Animation
angusstevenson123
Message 1 of 9
Gear Animation
angusstevenson123
I have what is probably an easy one.........
I am simply trying to get two gears spinning beside each other. ie......if one gear spins - then the other gear reacts and spins the other way.
I've sifted through online tutorials - but if anyone can hep me cut straight to the chase - that would be great!
All help appreciated.
Thankyou
Angus
Replies (8)
Message 2 of 9
TrippyLighting
You could try a contact set. The better method to do this, however, is a motion link.
Message 3 of 9
angusstevenson123
Thanks - any chance you could post a video of how to do this.........or a bit more of a break down of the steps involved.
Thanks - Angus
Message 4 of 9
TrippyLighting
Here's a little screencast showing the version with the Contact Set. I'll work on the other method while you try out this one.
Make sure your "parts" are components 😉
Message 5 of 9
angusstevenson123
Oh WOW - thankyou very much!
Message 6 of 9
TrippyLighting
Here's the same thing with a motion link between the revolute joints that the gears are assembled with to the base plate.
Feel free to click on Kudos and "Acccept as Solution" 😉
Message 7 of 9
angusstevenson123
Trippy Lightening - thankyou very much for the time you put into this solution. It cuts straight to the chase of what I was after. Thanks again - Angus
Message 8 of 9
arie.dv
That works great for equal sized gears. How do you make it work when there is a ratio between the gears? eg 1:4 16t driving a 64t. In my case both gears complete one revolution, instead 4 revolutions driving one revolution.
Regards. Arie.
Message 9 of 9
HughesTooling
You just put the ratio in to the motion link. Demo file attached.
Mark
Edit. I just realised you can break that down to 1 to 2.5 and  1 to 1 for the small gears, wasn't thinking it through when I set it up the fist time.Smiley Embarassed
Mark Hughes
Owner, Hughes Tooling
