G2 Fillets not Degree 5
I don't understand why Fusion's G2 fillets are Degree 3. Especially considering that it's brilliant patch command is Degree 5.
I know this has been covered in the past and that it might be a step conversion issue. Any idea when it will be fixed?
Thank you.
Mike.Grau
Hi @Anonymous,
Thanks for pointing to that. This is a great question.
We will stick our heads together and reach out to @jeff_strater and @Phil.E to get you the right answer.
We´ll keep you updated.
wilkhui
Hi @Anonymous - the G2 fillets we make are degree 4 and the approximation upon export makes a degree 3 surface.
We can set up a task to explore degree 5, can you help by creating a post on the IdeaStation for this?
Indy
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
