g code help 2d
g code help 2d
jordanbobsmith
g code help 2d
jordanbobsmith
so after finally figuring out how to post process and get my plasma cutting what i want. Its all of a sudden stopped working again. i have a g code script that does work on the machine and one that doesn't if posting them would help?  i use the jet demo post (which has worked previously), i'm using the free fusion version, really stuck on this now. I have tried modifying the g code myself which has made a difference but not fixed my issue. even if someone could suggest the correct post for me as the example i have that works was done on fast cam. i followed the youtube video by lars.
for the one that doesn't work i have tried removing all words and adding in m08 and m07 commands.
jordanbobsmith
Also might add would the words mess with the g code? The words in the g code that doesn't work, would these go away if I started paying for fusion?
