Fusion360 Spline Adjustment Issue
sfg18
sfg18
Hi! Somewhat new to Fusion and CAD as a whole so apologies ahead of time if my terminology is unclear.
I'm trying to connect one curve to another smoothly (both splines; one is projected from a separate sketch). However, the handle associated with the endpoint coincident to the projected spline can't be adjusted—only translated. My goal is to adjust the handle so that it is close-to tangent to the projected spline so that a "smooth" transition is achieved.
What's going on/why is this happening? Is there a workaround? Thank you!
TheCADWhisperer
@sfg18
sfg18
Here it is!
TheCADWhisperer
@sfg18
What is the function of the feature to be created from Splines?
I would use the simplest geometry possible to achieve the function.
Arcs and lines, if possible, rather than Splines.
I would consider Splines to be mostly limited to freeform organic art.  If you need splines, use splines, but I question if more basic geometry would suffice in this case.
Also, I observed that many of your dimensions appear to not have a logical basis.
TheCADWhisperer
@sfg18
I remodeled your assembly from scratch. (see attached)
I think you will have to come up with an alternate for the problem splines using arcs and lines.
sfg18
I just wanted to widen the curved path at its end to accommodate some thicker wiring (connected to components inside the shelled area). To be honest, this is more of a very rough prototype so there are indeed a lot of dimensions not fully thought out—I was just really confused why the control handle at the coincident end of the spline couldn't be manipulated while the other one could.
Will definitely just remodel the curve with new splines.
sfg18
Wow! This is amazing, thank you so much!
Your workflow is really refined and clear to follow; I haven't even had the chance to go through each step carefully yet and am already learning new things. I'll try to use arcs+lines and see what I can come up with.
