Fusion360 Cloud
Fusion360 Cloud
Aleš_Pavlousek
Fusion360 Cloud
Aleš_Pavlousek
I need to connect drawings of assembley to assembley in Fusion 360 Cloud. I have drawings in DWG formats, but it doesn't work, can anyone help me? Thanks.
Mike.Grau
Hi @Aleš_Pavlousek,
Thank you for asking about that.
It´s bit tricky to give you great answer.
Could you be a bit more specific of what you are trying to achieve?
Have you created a Fusion 360 design and derived a drawing from it?
If you may have copied a drawing and a design you see that the copied drawing always will be
associated with the original design. Currently, there is no option in Fusion 360 to connect the copied drawing
to the copied design.
I hope this helps.
Mike.Grau
Hi @Aleš_Pavlousek,
I hope my latest post could answer your question.
Could you may try as a kind of work around to copy a design with a related drawing and
export a related drawing as a "Fusion 360 Archive" file and re-import as *.f3z into Fusion 360.
I hope this information helps.
