- Mute
- Permalink
- Report
I'm trying to make some splines on an arch. I specified the inside of the arch, made some loft sketches, then lofted to get the outside of the arch (it's not a simple offset). I made another sketch (I couldn't project the loft onto the original sketch because it was earlier in the timeline) and projected all of the curves and lines that I was going to need. Then I specified my splines using tangent and perpendicular constraints. I tried to trim the original parts of the outside arc that I wasn't going to need, and I couldn't grab it. So I zoomed all the way in and I saw that the two splines weren't touching. I tried to delete the tangent constraint and apply a coincident constraint, but Fusion says the constraint already exists. In the zoomed-in screenshot, you can clearly see that they are not. I can think of some ways around this, but they will certainly be hacks that require extra steps.
This second screenshot is zoomed further out and shows where I am working
