Fusion Team Message at every start of Fusion 360!
janus2
janus2
Hello!
Every time I start Fusion 360, I get the message below. As a hobby user I do not need this. How can I turn it off permanently. It's annoying!
Jan
Phil.E
The way to make this go away is to convert your single user hub to a team hub using the tools presented by the dialog.
Once you move your data to the new team hub, you will see no difference in how you use Fusion as a hobbyist.
Phil Eichmiller
Software Engineer
Quality Assurance
janus2
Thanks for your answer.
But I don't understand why I have to do this.
As a single user, I don't need this. The effort just to stop the message?
Jan
NicolasXu
Hi @janus2 ,
Thanks for reaching out to us.
Fusion Team is the new design storage for Fusion 360 users. It has been the default storage for users who started using Fusion in the summer 2019 or later.
Fusion Team is a collaborative environment where you can store design data and work on your own or with collaborators. Whether you are the only member of your team or collaborating, you are always in control of your data and can define who can access it.
Here is an article explains how to start using Fusion Team and the benefits of the change. Though it's using Academia as the context, the idea should apply to you case.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/simplecontent/content/getting-s...
Hope it answers your questions.
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
The links that I'm supposed to login if the one on fusion doesn't work? I need to log in but cant. Why is this made so hard? really couldnt make this an easy change, i have been working on this ALL DAY LONG!
NicolasXu
Hi @Anonymous ,
Do you mean the link below? I don't think accessing it requires a log in.
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/simplecontent/content/getting-started-fusion-team-for-academia.html
The account you used in Fusion 360 is your Autodesk ID which can be used to log into all Autodesk products, including this forum.
Nicolas Xu
Sr. SQA Eng.
