Fusion Slicer LT addin question
fprico
fprico
I just download this addin for Fusion 360
https://github.com/tapnair/FusionSlicerLT
The thing is that I could not see some options in the FusioSlicer LT  window, like the spacing distance and the notches,
Any idea why this could be?
This is how it looks:
OceanHydroAU
With a quantity  of 1, you would not need any of those things, right?
Try bumping those numbers up?
fprico
I tried with diferent values but the options of custom slot size and spacing don't appear. I am using the version 1.0 of the addin.
JeromeBriot
As you see here, the lines of code corresponding to these entries are commented. So they aren't created.
Maybe @prainsberry can give you more information about this.
prainsberry
Hey, my apologies I had removed the ability to create "custom" notches as there were a number of issues people found.  It now just creates rectangular notches.
To be honest I haven't worked on this one in a long time.  Probably could give it another go at some point to add the "custom" notch feature back in.
If you create the slices now you and pull them apart, you should see notches?  There isn't an option though.  I need to update the docs though for sure.
Do you need the ability to create the custom notch?
Patrick Rainsberry
Developer Advocate, Fusion 360
