Fusion - Sheet Metal - Feature Request
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like the ability to switch to a different sheet metal rule after converting a customer-supplied model to a sheet metal component. The material thickness, inside radii, and bend deduction / k-factor need to match what's in the compensation table for my press brake programming software — if they don't, the flat pattern sent to the laser will be the wrong size and the programmed punch depth will be incorrect.
I would also appreciate the ability to use bend deductions instead of k-factors in the sheet metal rule, since converting from bend deduction to k-factor is an unnecessary step most of the time.
I currently maintain a sheet metal rule for every combination of material, thickness, punch radius, and die opening.
